2 members (Peggy M, UtahYork),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | I am putting new 3/4" bed boards on my 51. All seem to fit ok but the front of the outer board will not fit between the front cross member and the angle. 5/8 is the max that will go. Lifting the bed will not help because the front bed panel is bolted to the side panel so everything moves up. I loosened the side panel to front panel bolts to get a little more clearance but that did not help. The bottom of the front panel also has a lip formed to it that also prevents the adjustment for a 3/4 board. My only thought is to machine the bottom of the front of all boards about 3-4" back to 5/8" so the end boards slip under the angle and the other boards are even with the outer boards. I do not want to cut the angle welds and repaint. Any other thoughts? Thanks, Howard | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | That's the beauty of wood - you can cut and sand it to fit. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Did you re-weld new angles on to the bedsides?
| | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | How's the fit at the back cross member? Is the bottom lip on the front panel bent up?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | I did not re-weld the angle but the PO might have. The rear cross member fits the 3/4" perfect. The front panel lip is not bent. Machining 1/8 Off 2 1/2" back from the bottom front of each board is beginning to look like my best bet since it will work and not show.
Thanks and have a happy Thanksgiving. | | |
