10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible), 50 guests, and 0 robots.
Topics128,080
Posts1,055,944
Members48,430
#119204 01/19/2006 3:03 AM
I just bought a new tailgate ,front bed panel and splashpan are these ready to paint or should
I primer them first,like the rest of the truck
#119205 01/19/2006 5:42 AM
I believe most replacement bits have a primer coat on them and are ready for top coat. To be sure you'd best ask the supplier. But everyone I have seen were paint ready.
#119206 01/19/2006 5:31 PM
The body panels are black and the rest of my truck is primer gray will their be a color difference when I get it painted if I dont primer it.
#119207 01/19/2006 5:34 PM
How is the panel construction compared to the originals? I've bought aftermarket panels for another truck and been very disappointed in the steel thickness compared to the originals.
I can't help you with your question as I'm not quite to the same point yet. But I'll be interested in the answers.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#119208 01/19/2006 7:13 PM
I have new panels that have black EDP coating and others that are just raw steel. I asked this forum if I should shoot 2-part urethane over the EDP because that would be the same primer I would use on the raw steel (after etch-primer). The consensus was that it would be a good idea to scuff the EDP and spray 2-part urethane in order to make sure that paint was applied to the same base. It also allows you to block-sand the panels to make sure they are perfectly straight.
#119209 01/19/2006 11:48 PM
Thanks for the help I will light sand them and primer them. RedGreen I got them from chevy duty
and they seem as sturdy as the originals and they were packed very securely
#119210 01/20/2006 4:44 AM
Junior Member
Junior Member
For something like the EDP coating, which is quite thin, I reccomend using a scotchbrite pad to scuff up the factory primer. The red pad has served me well for coating with primer. They conform to irregular surfaces better than sandpaper and you're less likely to scuff through the primer. Your local automotive paint store should have them in big sheets like 8x10.
Joe
