6 members (Jon G, Hotrod Lincoln, rfs56trk, BC59, Robert Crandall, Gray_Ghost), 94 guests, and 1 robot.
Topics128,122
Posts1,056,331
Members48,439
#1191974 11/22/2016 6:56 PM
53 3100 with a rebuilt 235. Manual choke, electronic ignition, Rochester 1 bbl carb. When starting cold it idles and runs like new. I can drive it about 10 miles and it will not idle. Just like you turned the key off at an intersection. It will instantly start up and run after that, but will not idle. I can let it cool down @ 10 minutes and it will idle fine. Any ideas? Thanks
DLBrooks
DLBrooks
I take when it is cold you have the choke on or partially on. When choke is released--pushed in --- does it die? I would start with idle screw until it will idle --- and idle mixture screw may need adjustment. Start with idles mixture screw 1 1/2 turns out then adjust idle screw until it idles. Idle speed somewhere around 600.
1959 GMC 100 Fleet
Follow in the DITY
BTW....that's clockwise from 2-12 turns out. I do a 1/4 turn till it starts to bog down then counter clockwise.
I also would look for a vacuum leak if you have no luck with the idle air. At idle a vacuum leak is much more noticeable.
ODSS Lawman
ODSS Lawman
Hang on
Before you adjust yourself out of running, lets start with the basics.
First anytime an engine will not idle, vacuum leaks are first suspect. What have you done to find any? What approx. RPM is your idle set?
With cooler weather, it takes more time for these engines to run at idle correctly.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
It will idle with the choke pushed in. It will idle well until I drive it @ 10 miles or so. I have not looked for vacuum leaks yet. With the electronic ignition, I don't think I have a vacuum advance, but I will look for vacuum leaks. I think idle rpm is 600-750. It idles great in the driveway, but after a short drive it won't. Thanks for the responses and I will check for vacuum leaks.
After running for 10 minutes will it idle with the choke partially out?
I have not tried that. I will try and let you know.
