| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | I have a situation where my 1/2 ton original frame is just about had it,rust,stress cracks and cracked crossmember. Heres the delimma, i bought a 3/4 ton truck for the cab and other vital parts. It did come with a complete redone and painted frame but i had no real liking for the longer frame and where i live well selling it would not be easy. Has anyone shortened them for the 116 inch wheel base for the 1/2 ton, i know there is some re fit work for parking brake,hangers,drive shaft,running boards etc.Has anyone done this and how do i go about it. I have whatched newer c10's ( 69/70) done from long box to short box and i do have a certified welder in my area that can do the proper work. Please help!
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Make the frame cut in a straight section at a 45 degree angle for maximum length of the weld bead, and use fish plates inside and out for reinforcement. That's how we did it on tractor-trailer rigs that carried a lot more stress than a pickup frame. I've shortened and lengthened frames that way with no problems. You should be aware that the springs, axles, and a lot of other items are different on a 3/4 ton so you'll probably encounter a lot of fit and interchange problems. Jerry
| | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | Thanks Jerry, i have taken all that into consideration. So i will make the dive and do it | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
