Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1191070 11/16/2016 3:42 AM
This is for a big bolt, but I'm looking everyone's opinion as I'm sure it's not just particular to them.
I need to remove the oil pan on my '35 1 1/2 ton to fix the oil pump screen. It still has the original 207. Can it be done without taking motor mounts lose and raising the engine? I have it lose and the front will just barely drop down behind the front cross member. The back won't come as the back end just sits down on the rear cross member. What to do?
Y
yar Offline
Y Offline
"I have it lose and the front will just barely drop down behind the front cross member. The back won't come as the back end just sits down on the rear cross member."
NJA,
It seems that you've answered your own question. If you can't lower the pan won't you have to raise the engine? I have that same engine in a '36 high cab pickup.
Ray W
Ray
A lot of the times all you need to do is to turn the engine over slightly so the crank is out of the way, this allows the pan to clear.
My Blog
