| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 3 New Guy | | New Guy Joined: Aug 2012 Posts: 3 | Hi guys, I got a 1958 Chevy Viking 60. I was wondering if Lmc or someone has a catalog with parts for my truck? Or if the half ton truck seals(fender seals,fire wall,door,windows,etc) are the same for the 2 ton trucks? I also need new windows, brake cylinders, gas tank(behind the seat) ,bench seat. Thanks for any help. Brandon
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Brandon - there aren't any catalogs specific to the big bolts - you'll find that anything related directly to the cab [seat, gas tank, windows, doors, dash] and many/most things under the hood will be the same for any size conventional cab truck - chassis/brake parts will be harder to come by except for good used, but some folks here may have leads for specific items
Bill | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | There's plenty of GOOD links right here in Stovebolt! Just go to the "Links",and click-on any of the topics you're interested in! I bought the gas tank, (same size for pick-ups,as well as big Bolts),from L.M.C.,as well as the fuel pump.I believe that all of the external engine parts are interchangeable between the 235,and the 261.There are several different warehouses that supply a vast amount of parts for our trucks,even though they're geared more toward our little cousins. A great source for engine questions/parts,as well as intake/header-exhaust,(if interested),is Patrick's Antique Performance,Casa Grande,Az. I called them with my engine #'s,and found that I have a 235 head,and a 261 block. My engine is also S.C.O.,which means it doesn't use an oil-filter. I asked them if they had a by-pass system available,and instead of trying to sell me their kit,(one is available),the guy said,"How old are you?" I replied,"55". He said:"That truck is older than you are,and it's been doin just fine without an oil filter,so why add one now?! That's what I like about these guys! TRUE STOVEBOLTERS! They are more than happy to help you with your project,but they won't try and sell you something you don't really need! Another great source for engine and cab-parts is Jim Carter. I usually shop between all the "Jobbers" I mentioned. They all provide great service,as far as my experience. Hope this helps. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Hey Wetwilly, Just thought I chime in on the gas tank topic. The pickup truck tank (17.5 gallon) will work in any of the different size trucks as you mentioned, however the really big bolts (56-59 Series 7, 8, 9 & 10) had a 21.5 gallon tank. It has a different pickup/sending unit, longer hold down straps and a different filler neck. Mike B  | | | | | Joined: Nov 2016 Posts: 6 New Guy | | New Guy Joined: Nov 2016 Posts: 6 | where can i get a REAR brake hold down spring for a 1958 Chevy 60 Viking truck. please contact me 3605502393. i have pictures | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy MelodyM, could you post the pictures here please? Are you actually looking for a hold down spring or are you looking for pull back springs? | | |
