1 members (klhansen), 160 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
#119045 01/07/2006 1:12 AM
Anyone around the dallas area know a good place to get some soda blasting done. i've found some for sand blasting but nothing for soda. also about how much to get a whole cab blasted?
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
Anonymous
Unregistered
Anonymous
Unregistered
The soda blasting seems to have caught on well with the sailing and power boating segment. Try calling some marinas to see if they can refer you to someone.
I also recall on a Rides show that Unique Performance there in Farmers Branch used a soda blasting outfit to do their mustang bodies. Give them a call and see if they will give you a name and number.
Ive seen ads in the Ft Worth Star-Telegram for blasting, closer to FT Worth than Dallas area, I did recall a number of years ago, a place around Cedar Hill, or Desoto. check Hemmings, may be in there..
I found this ad today, for the Dallas/Ft Worth area........ Soda Blasting, mobile paint removal 817 875 5502 www.atozsbs.com
A place in Sanger advertises plastic media blasting. I haven't used them but you might want to get a price from them. 940 458 3326
Let us know who you use and how it turns out.
Just bought a project, probably with 3 or more coats of paint, will have to call them. Anyone have any luck with a liquid paint stripper? A stipper that is eco-friendly?
Anonymous
Unregistered
Anonymous
Unregistered
If the funds are tight and if you are working the truck panel by panel, just use a knotted wire wheel on your grinder. It will take the paint off in a hurry after which you can use a DA sander to scuff the surface for a good profile before priming. Just remember to use a face shield, gloves and a respirator mask.
