| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Hey guys. I'm new here. I've been searching different sites and I can't find a VIN decoder for my 47 loadmaster. Here's a pic of the tag inside the door. 9QW G 1922. I've only figured out it was a 47 by looking at pictures and reading about the differences between models. I don't know much else about it. 1.5 or 2 ton? Engine size? [IMG]http://i1153.photobucket.com/albums/p517/ljbluejason/Mobile%20Uploads/IMG_0289_zps7cyupx85.jpg[/IMG] | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | with a GVW of 16,000 and also the bolt on front wheel bearing covers, I believe you have a 2-ton. 1 1/2 ton wheel bearing covers did not bolt on.
Both my newer 2-tons are also rated for 16,000 GVW. | | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | You were right on sir. Shortly after I posted I found the decoder I was looking for. 2 Ton built in Ohio in July 47. 161" wheelbase and from what I can find, that size only had the 235. Thanks! | | |
