2 members (Peggy M, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,052
Posts1,055,774
#119009 01/04/2006 10:45 PM
Do I have to order this from them, or can I buy it locally?
Thanks, Shoop
#119010 01/04/2006 11:05 PM
Why not ask them yourself? www.por15.com
It took about 1 second on Google to get their website.
1954 GMC De Luxe COE
#119011 01/05/2006 5:54 AM
My FLAPS has it.
Dunno about yours.
#119012 01/06/2006 1:06 AM
most of the auto paint shops and flaps are starting to see this product out here in arnold country. it's been a scarce item w/ their marketing group. keep asking. they still do not have all they should nor do the shop employees know what or how to use it very well.
which leads me to ask:
does one have to use the metal ready before using ANY of their paints. ie manifold heat ??
i guess if i want to know i should google...
http://www.por15store.com/POR-15-Product-Instructions.html
hope that helps everyone.
Jim & Caroline
#119013 01/06/2006 7:10 AM
Yes, from what I understand. I tried POR15 on a rusty panel once without using their recommended metal prep, and once it dried, it peeled right off like latex paint, and the surface rust looked exactly the same.
I'm concerned that their product merely covers it up, rather than neutralizing it.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#119014 01/06/2006 3:38 PM
I have seen vendors at swap meets selling POR-15.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#119015 01/06/2006 5:20 PM
Rusty, at the Rust Store is carrying POR-15 now. He might be able to answer your question, too. I'll forward this on to him.
Peg
~ One of many.
#119016 01/06/2006 6:07 PM
Caroline's Truck:
It depends on what the surface you apply it to is made of. If it's non-ferrous, then absolutely. If it's not rusty ferrous metal, then yes. If you've got some rust, then go for it.
They recommend that you power wash any grease off the surfaces with the degreaser agent before using metal ready.
Hot Rod Dad:
It seems that you need to prep a non-rusty surface, and anything that you want to paint that's non-ferrous metal. If you have a rusty surface, make sure you knock off all of the loose rust (the stuff that falls in your eyes when you're screwing around underneath the truck) and any large scales. You shouldn't have any problems.
#119017 01/10/2006 12:46 AM
HR-Dad
to answer my question of using metal ready on surfaces b4 painting w/ these products. You just can't use the ferrous non-ferrous idea.
DO NOT USE metal ready B4 painting any exhaust manifold heat type POR paint. They can not stand the heat and will cause the paint peel.
and no I didn't find out the hard way...
Jim & Caroline
#119018 01/10/2006 6:05 AM
For what its worth you can use Zero Rust on already rust metal and it won't rust through (at least it hasn't for the past 3 years...) Just knock off the loose stuff. ZR is thick though, so you'll have to use it in a pressure pot gun.
#119019 01/10/2006 5:36 PM
Has anyone used their engine paint? Can it be brushed on with good results?
#119020 01/17/2006 1:02 AM
RT,
after using the por 15 and por 20. I would say yes
Jim & Caroline
#119021 01/21/2006 12:57 AM
Z
Junior Member
Junior Member
Z Offline
I used their engine paint and brushed it on and it worked great. Chris
#119022 01/28/2006 7:09 AM
Junior Member
Junior Member
I second what Zeeklu said. I used POR 15 red/orange Ford paint on the motor of my 57 T-bird. Two years and looks as good as the day it was applied.
John M. (Marc) Knight
VTCI #33786
Thunderbirds, 64s, 57, 2002
40 Chev Truck (Rat) project for my 16 year old daughter
Bountiful, UT
