Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (66flea, farmallb, EchoBravoSierra, Shaffer's1950, 1 invisible), 60 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#1189900 11/07/2016 1:31 AM
Just recently have my '59 235 on the road after a complete nut-and-bolt. With the engine up to temp pushing the choke knob so the butterfly is all the way open kills it. I have to run with the knob about 1/2" or so out.
Normal? Or does that suggest the carb is set a little lean?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
Suggests a vacuum leak around the carb or a gunked up carb. Start her up and get out your unlit propane torch and slowly pass it around the carb. Listen for the engine to speed up. JMO
