0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | First I want everyone to know I tried to search the archives for this info. I've got several TF trucks and have had no success finding the name or code for the interior color used on the metal components. I am referring to the gold/bronze/champagne whatever color that seems to be so prevalent among trucks of these years. Any help? Even a color name would be helpful.
Joe | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Don't know what year your truck is, if it's an AD try this thread from awhile back. You can kind of see the color on my web photos page. BTW welcome to the Stovebolt Page!
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Welcome Joe, hope your not flooding.
If thats your truck AD Pickup, its beautiful!! | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | I put in the original post that the color is for a task force truck. Specifically I am inquiring for a 59 i ton I am currently working on. I've got many other TF trucks. It's a disease. We got a reprieve from the rain today, tomorrow is supposed to be biblical. Old guy next door is building a big boat, hmmm. Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 2-tone TF interior colors I've seen are called granite gray and marble gray - unknown on the goldish one that seems to be in some later ones - haven't seen that anyone has come up w/ any codes for any of the TF interior colors
Bill | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | The color name for 1959 is called "Comanche Gold Metallic" and its DUCO code is 92863. The trim color for this color scheme is "Charcoal Gray" and its DUCO code is 73605. While the DUCO code for Comanche Gold Metallic does not come up, the Charcoal Gray code does. Jim Carter has a local paint shop mix up the Comanche Gold Metallic substitute color that he sells as "Silver-beige" and it is a good match to the original color. I used his paint for the silver-beige color in my cab. Jim Carter's part number for the correct silver-beige [Comanche Gold Metallic] color for a 1959 TF truck interior is: PT-150. The Charcoal Gray was mixed up by our local paint shop using the above original code. Here is a link to my website with pictures of my interior painted in the Silver-Beige and Charcoal Gray colors: http://www.59apache.com/bigwheel.html Here is a link to a 1959 Dupont Chevrolet Color Bulletin http://www.59apache.com/pics/151959DupontB31S5.jpg It is the document that I obtained the old codes above from for your reference. I hope that helps! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Woog linked a site in another thread that has the chip sheets I've seen for for 58-9 [no mention of the Comanche Gold] - and the one that lists the granite and marble gray - wonder if just certain plants used that gold color? :confused: Bill | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Jim, thanks for the information. I checked out your web site and that gold looks like the right color. I'm going to reassemble the deluxe heater this weekend and reinstall the hydrovac after having it rebuilt locally. Wish me luck!
Joe | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Bill, I think if you look closely at the chip sets you posted the first one is for 1958 and the second one is for 1957. The one I referenced is for 1959. Each year the TF trucks listed different interior colors for 1956, 1957, 1958 and 1959. Take a second look and you will see what I am talking about. Notice the bulletin numbers at the top of each page and the year indicated in the text just above the DUCO lacquer color formula info. I have copies for 1956, 57, 58 and 59. I can post each of them if you would like to save them. Or, send me a private e-mail if you want, and I will e-mail them to you as well. If you want them, just let me know.  | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Joe,
your welcome. Good luck on your reinstall. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | AD_Pickup, Do you have the color codes (and Manufaturer) for the interior of a 52-53? | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Rattletrap 52,
I have a Dupont color code for the 1953...
Instrument Panel (All Models Except Surburban) Duco Stock Order Number... 740 Duco Code... 202-81407 Sheen Gray Metallic | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Jim, if you would not mind, I would really like to have the chip sets emailed to me for the years you listed. I have more than one of these TF trucks so info for other years applies. Thanks
Joe | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Joe, Check your e-mail!  | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Thanks very much Jim. Those chips will be handy later on. I took a closer look at how things were painted in the interior this weekend. The top of the dash is textured black and the dash face is gold. The steering column and column drop are charcoal or something similiar. From memory, I believe everything else was gold. Nice to look at original trucks. Most of the stuff I see is redone/modified and is no longer a information resource.
Joe | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Joe, The top of the dash should be Charcoal Gray and you can add flattener to just the top part not the face of the top just before the bend for the stock look. The black textured paint is not a factory option for our year but was a popular aftermarket treatment applied to many of these old truck dashes to reduce glare from what I have been told. Jim Forbes of Sierra Vista Arizona really helped me get my truck painted with the correct original colors. I also confirmed my plans against the materials Bob Alder Bob Alder owner of Alder\'s Antique Autos, Inc. of Stephentown, NY. sent to me in his restoration packet. Here is the scheme - The following item should all be painted Charcoal Gray: Steering column Steering wheel column bracket Steering wheel Dash top Dash face above the role Emergency brake handle Emergency brake handle bracket Step well floors Cab floor Clutch pedal Brake pedal Accelerator pedal Bench seat frame and purch Tire jack mount The item below should be painted in the gold color: Interior doors Kick panels Dash front Vent covers Door jams If you need close-ups of any of these areas, let me know and I will send you a picture of them. | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Oops, well I've repainted some stuff wrong then. The parking brake handle assembly is now gloss black. What was left of the original paint looked like black. The tranny cover is black as well. When I take some good photos I'll email them to you. MOst of this truck seems to be very old and I assume original although you've pointed out that doesn't apply to the dash top.
Joe | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | Joe, I am sure your truck will be looking great! The main thing is just enjoy it. I can't wait to see your pictures.  | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Oh you can wait, believe me you can wait a long time. I'm not sure if I already stated this, but the 59 is a working truck. Nothing pretty here folks. The work I've done is done well but there are plenty of untouched areas that are umimproved since the assembly line workers built the truck. I'll email the pics to you. Just drove the truck home towing a trailer with car. Gawd am I tired, old trucks require work to drive.
Joe | | |
