1 members (baldeagle), 56 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#118925 12/28/2005 3:16 AM
My 52 chevy appears to have originally been blue. What was the actual color name and does any one know a paint code that I can use to buy a close match?
#118926 12/28/2005 4:28 AM
welcome to the shop mr! someone may come along who's accomplished the same hunt yer on, but you'll probably have to end up 'close enough'
check here or maybe here - prolly Admiral blue or Twilight blue - problem is the old paint codes are laquer and there's no easy crossover for the modern paints
#118927 12/28/2005 4:59 AM
#118928 12/29/2005 8:08 PM
Thanks for your help. Mariner Blue it is.
Anyone know a modern code that is a close match?
#118929 12/29/2005 11:05 PM
PPG should be able to help you (however, your local PPG jobber might not want to pursue this).
Try calling one of the phone numbers below and give them PPG-10419 (originally Ditzler, DQE-10419) as the code and tell them the year/color you are looking for (1952, Mariner Blue). Mariner Blue changed in 1953 (different shade and different code - same name).
440-572-6100 PPG Color Library - had all codes
440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
The above numbers are 6-7 years old. If you try any of the numbers, would you please post if they are still good?
#118930 12/30/2005 4:59 PM
I don't see why you couldn't color match a modern acrylic urethane paint to an old lacquer paint. The lacquer does not change the shade! You should be able to color match any paint out there.
Or, he could repaint in lacquer if he wants to. It's a very forgiving paint that is easy to work with. If it's kept in a garage, the paint could look good for many years.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
