| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | My 52 chevy appears to have originally been blue. What was the actual color name and does any one know a paint code that I can use to buy a close match? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop mr! someone may come along who's accomplished the same hunt yer on, but you'll probably have to end up 'close enough' check here or maybe here - prolly Admiral blue or Twilight blue - problem is the old paint codes are laquer and there's no easy crossover for the modern paints Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | Thanks for your help. Mariner Blue it is. Anyone know a modern code that is a close match? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | PPG should be able to help you (however, your local PPG jobber might not want to pursue this).
Try calling one of the phone numbers below and give them PPG-10419 (originally Ditzler, DQE-10419) as the code and tell them the year/color you are looking for (1952, Mariner Blue). Mariner Blue changed in 1953 (different shade and different code - same name).
440-572-6100 PPG Color Library - had all codes 440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
The above numbers are 6-7 years old. If you try any of the numbers, would you please post if they are still good? | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I don't see why you couldn't color match a modern acrylic urethane paint to an old lacquer paint. The lacquer does not change the shade! You should be able to color match any paint out there.
Or, he could repaint in lacquer if he wants to. It's a very forgiving paint that is easy to work with. If it's kept in a garage, the paint could look good for many years.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
