2 members (Svcattle, baldeagle),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | OK, '46 Panel windshield division bar. I've got the inside flat bar, inner and outer gaskets, the center divider rubber and chrome outer moulding. Now what I don't have is anything for the bolts to connect to from the inside to the outside and I don't see how the chrome moulding mounts. Is there another bar or nuts thats supposed to be inside the chrome moulding to mount the whole thing?? I'm so lost...... If there is supposed to be something inside the moulding anyone know where to find it. I've looked at all the parts listings and can only find complete center bars or rubber parts. Thanks.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check out the Tech Tip re. 39-47 windshield repair, talks about this division bar. I ended up finding a so so used one on my 46, these things are a bugger to restore. You may want to place an ad on this site for a used one. | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Bluepen The rubber strip mounts inside the chrome strip and has the fasteners moulded into the rubber. You can buy the whole unit for around 90 bucks or like I did was just buy the rubber and mounted it in the chrome strip. I think i got mine from steele rubber or chevs of the 40's. If you can't find them there let me know and I will look for the bill Stuart | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Bluepen Here is the link to steele rubber. They have a good picture http://166.82.96.9/xframes.html | | |
