Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
OK, '46 Panel windshield division bar. I've got the inside flat bar, inner and outer gaskets, the center divider rubber and chrome outer moulding. Now what I don't have is anything for the bolts to connect to from the inside to the outside and I don't see how the chrome moulding mounts. Is there another bar or nuts thats supposed to be inside the chrome moulding to mount the whole thing?? I'm so lost......
If there is supposed to be something inside the moulding anyone know where to find it. I've looked at all the parts listings and can only find complete center bars or rubber parts.
Thanks.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
Check out the Tech Tip re. 39-47 windshield repair, talks about this division bar. I ended up finding a so so used one on my 46, these things are a bugger to restore. You may want to place an ad on this site for a used one.
1946 1/2-Ton Chevy
Bluepen
The rubber strip mounts inside the chrome strip and has the fasteners moulded into the rubber. You can buy the whole unit for around 90 bucks or like I did was just buy the rubber and mounted it in the chrome strip. I think i got mine from steele rubber or chevs of the 40's. If you can't find them there let me know and I will look for the bill
Stuart
Bluepen
Here is the link to steele rubber. They have a good picture
http://166.82.96.9/xframes.html
