2 members (BC59, 1 invisible),
152
Mod | | | Forums66 Topics128,088 Posts1,056,110 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Not exactly an electrical question, but it relates to the gauge cluster. I am about to install my cluster and am wondering how the sending unit routes through the fire wall. When I got my truck, it was using an after market under dash gauge. The sender ran out through the 4 hole grommet in the center of the fire wall. I don't see how the temp sender that came with my replacement gauge is going to fit through one of those tiny holes.
Bob
BobS46
| | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi you have to remove the grommet out of the retainer that bolts through the fire wall. The rubber grommet should have a horizontal slit through the center of the small holes allowing you to widen and push the bulb through. When you reinstall it back in the retainer it holds it tightly again. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Bob, This firewall layout may be of help to you. As stated in another post , remove the 4 hole grommet and insert the line and then reinstall the bracket and you are good to go! Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks a lot. I don't believe mine has slots cut in the grommet - that thought has already crossed my mind. But, they should be easy enough to cut. I just wanted to know the "right" way to do it.
BobS46
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks Harold. Most of that info I had figured out or stumbled into. But it is nice to have it confirmed. Also, the vacuum hose location was new to me.
BobS46
