1 members (LAROKE), 86 guests, and 4 robots.
Topics128,179
Posts1,057,160
Members48,465
I have a 40 1 1/2 ton can I swap the internals from a later syncro 420 into my non syncro case. I want to keep the orig drivetrain with the torque tube setup.. Thanks in advance
Nope, not even close- - - -the 420 is a much larger and more rugged transmission with bigger gears, bearings and case size.
I was under the impression that the early SM420 like mine are no syncro in any gear. The later SM420s were syncro'd in 2nd, 3rd and 4th. They're not the same basic trans, same case???
' Offline
1954 3600
Now cruising in
The Passing Lane
Red dot, center of chest ...
Looks like you might be able to do it with this conversion. http://www.novak-adapt.com/knowledge/transmissions/manual/sm420
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
If your 1940 transmission is original, none of the gears are synchronized.
Lots more pictures
Here are 1940 transmission specs. Looks like no synchronous meshing gears in 1940 4-speeds.
As shown in the Novak Transmission info, the SM420 was introduced in 1947 (probably for 1948 trucks).
Mcatt,
Your tranny is not a SM420. As others have said, there is nothing interchangeable with your tranny and the SM420. SM420s where used with torque tube driveline, but your torque tube would be too long and would require modification to fit a SM420. Alternatively, you could modify your driveline to open drive and use the SM420. Both choices are difficult and require professional skills.
Let me ask why do you want to change out the tranny? If it needs repair that is the easiest solution . If you don't like to double clutch, I would encourage you to practice more until you are good at it. Once you get this skill, you won't want to go back as it is part of the character of these older trucks.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Oh. I thought it was a sm420. And yep it's original what ever it is. The same bonehead that left the engine open to fill up with water and lock up let water get in the trans. The forward gears are rusted up as well asthe main shaft and won't budge. Thought upgrading would be easier and better than repairing. Found a sm420 from a 53 gmc but discovered it won't bolt to my bell housing. Have the entire gmc 1 1/2 ton chassis with open driveline and 2 speed axle.
Ok. Next dumb question. What tranny do I have. It's original. Has the little lockout lever and rod. NO syncros at all. Yeah I'de fix it if I can find the parts. The clutch clutch thing is cool with me. Not a racecar don't think it will ever really haul much.
Crusing in the Passing Lane
Entire GMC 1 1/2 ton cassis would have lots of useable parts-axle, driveline, trans. Bellhousing-GMC engines are slightly longer than Chevy's, easy to move radiator FWD an inch or so. GMC displacement is start of SN, I.e. 248xxxx, stamped on right side, behind distributor. Might be better than yours?
Ed
Check your private messages.
