3 members (Nick in Manitou, Hotrod Lincoln, TUTS 59), 123 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#1188875 10/31/2016 1:19 AM
Offline
I put a 1959 235 engine in my 1949 Chevrolet pickup.
It is a bear when it is cold. I have put in new points, condenser, distributor cap, vacuum advance, plugs, wires, rebuilt the rochester B carb twice, and it still gives me fits when it is cold. It sits there and idles beautifully and it runs much better when it finally warms up, but it still feels as though it is starving a little bit.
Any suggestions. Thanks. Would appreciate any advice.
Does it still have a choke pull-off diaphragm?
How was the choke blade adjusted?
Offline
It is a manual choke, but even when I close it half way it still coughs.
Is the heat riser free?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
H Online: Content
My thoughts exactly- - - - -fix the heat riser!
Lack of a functioning heat riser means the manifold is dead cold way too long, requiring rich mixture when it's not necessarily what the engine wants.
Closing your manual choke cable half-way isn't where it should be for dead cold - it's still too lean.
The choke blade is normally fully closed when cranking, but once it starts you should open it 5/32" measured between the edge of the choke blade and the throat. Use the stem of a 5/32" drill for this, and mark the cable position in the cab with a piece of tape or a stop.
The Model BV diagram shows where http://www.chicagocarburetor.com/pdf/Instructions-Rochester-B-BC-BV.pdf
The truck can and should be driven in that position at light throttle.
Open the choke with the cable gradually as the manifold heats up. You'll know it's still too lean when it hesitates as you roll the throttle on.
You might also make sure the thermostat isn't stuck open. If it is slow to warm up the heat riser and thermostat are 2 of the most common problems. You also have to remember that it takes longer to heat up 700 pounds of steel than it does 300 or so pounds of steel and aluminum in newer lighter engines.
If you think your 235 runs cold for too long try waiting for the V12 diesel in an M60 tank to warm up.
Corvair?
215 Buick?
Can't think of any modern engine under 400. My Toyota 3.0 L6 is about 500.
What carburetor did you use?
If you are using a carb from a smaller engine, 216, it may never run right.
Joe
