0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1188063 10/24/2016 3:32 PM
Hello,
I've been asking a lot of brake questions lately, but I figure stopping is rather important. I've given up my search for P30 axles to swap in for now, so it's back to trying to fix the OEM brakes. Having a hard time finding information about certain parts though. I'm sure the hardware sitting inside those drums is tired. Namely the springs. If it's like any of the other spring on the truck they snap under the slightest stress. I've had a hard time coming up with any part numbers, or anyone still saying they make brake hardware kits for a 1951 Chevrolet 6400. I've found wheel cylinders, I know where to have the shoes relined at locally, brake lines are pretty straight forward, but hardware seems tricky to find. Any info would be appreciated.
Kyle
Big Bolt Forum Moderator
on my 1958 6400, the brake return springs were no longer available. I called the local Brake and Clutch supply in Seattle and they looked up a part # for me. I found some on Ebay. You might call the local place that is going to reline your shoes and see if they can get them or at least find you a part # in one of their books.
Mike
Kyle,
Is this what you are looking for?
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEB147&i=10247|||||
This is a link to Jim Carter's site. Check out other vendors including the Filling Station.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Link doesn't work for me? I tried navigating Jim Carter's website last night. They need to redesign it badly. I couldn't get anywhere with it.
Ah, it's their mobile page that doesn't work well. Went to web version, and now it all works.
Try this: Brake Springs
