2 members (stlcardinalsguy, moparguy), 77 guests, and 1 robot.
Topics128,132
Posts1,056,731
Members48,454
#1187669 10/21/2016 1:43 AM
I'm having a local shop convert the 4.11 in my '53 3100 to 3.55. Are there any particular "break in" precautions when I pick it up?
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
ODSS Lawman
ODSS Lawman
Prior to pickup the installer should, if following directions, should run in high gear for 15 min with the wheels in the air.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Thanks, Sweet, I'll check with them.
~Denny
1953 Chevy 3100
Y
yar Offline
Y Offline
"Prior to pickup the installer should, if following directions, should run in high gear for 15 min with the wheels in the air."
Sweet,
That's an interesting concept. Which gear manufacturer recommended it? I've read various authoritative break in procedures but have never encountered that one.
Here's what Randy's recommends:
https://www.ringpinion.com/TechnicalHelp/contentframe.aspx?filepath=~%2fcontent%2fparts%2fringandpinions%2f%2fnew_gear_break-in.inc
Ray
Insomniac
Insomniac
Sounds dangerous! eeeek
Gord 🇨🇦
1954 1/2 ton 235 4 speed
ODSS Lawman
ODSS Lawman
The installation directions that come from Patrick's include this procedure in its installation instructions.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
