Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (51sub, Bill Hanlon, BC59, 2 invisible), 133 guests, and 2 robots.
Topics128,288
Posts1,058,571
Members48,492
#1187225 10/18/2016 2:31 AM
Moderated
Moderated
1 Offline
I was wondering if anyone had ever heard of this swap or how much work it would take to make it fit with a 4 speed trans. If i did this swap i would keep as close to original as possible so if i ever want to i can put back the 235 and hydramatic.
GMC used the 287ci Pontiac V8 in the 1955 pickup so parts should be available for a straight out swap. You don't say if it is the granny 4sp you want to use but if just a 4sp then many many GTO's, Firebirds, Trans Ams, etc came with 4 speeds on 389 engines.
Evan
Double posting won't get you better answers.
Crusing in the Passing Lane
Make sure your Pontiac crank is drilled for a pilot bushing, it probably is.
Ed
Did they use the Pontiac engine in the 1st series 55?
If you are referring to a GMC, there was a 54/55 Z-series (47-55 New Design body style). There were no small truck 8-cylinder engines available in the Z-series New Design 1955 GMC trucks.
The 8 cylinder engines in GMCs small trucks became available in later 1955 (Y-series - go figure) Blue Chip GMCs.
Carburetion specialist
Being ridiculously "picky", no Firebirds, Trans Ams, etc came with a 4 speed on a 389 engine; as neither were introduced prior to the demise of the 389 wink
Of course, the 4 speed with the 400 will fit the 389. thumbs_up
Jon.
The Carburetor Shop
But the Pontiac Grand Prix and other Pontiacs with 389 did offer 389 with 3 speed manual, 4 speed manual or automatic.
http://www.oldride.com/library/1965_pontiac_grand_prix.html
I had a 1965 pontiac catalina 2 door hardtop, black on black bench seat and a factory 389 and muncie 4speed. THEY WERE OUT THERE.
One of the problems to overcome when putting a V8 in an AD truck is getting the left manifold to clear the steering column and box. On a 389 you also have the starter on the left side. It is going to be difficult to "keep as close to original as possible" while overcoming these problems.
Of course it can be done but it is going to be work. And it will be way cooler than a SBC engine.
