Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, 1 invisible), 145 guests, and 5 robots.
Topics128,288
Posts1,058,581
Members48,492
#1187237 10/18/2016 3:28 AM
Moderated
Moderated
1 Offline
I was wondering how hard it would be to swap a 389 and a 4 speed into a 1954 Chevy that has the 235/Hydramatic? If I do this swap I am hoping to keep it close enough to original so if I ever want to I can put back the 235 and automatic
Double posted question
DLBrooks
DLBrooks
I like your idea, Nothing some fabrication can't take care of.
1959 GMC 100 Fleet
Follow in the DITY
no harder than putting a big block olds or a diesel into these trucks.
Riding in the Passing Lane
you will need to remove the crossmember under the bell housing & install one under the engine & trans. You will have a clearance problem with the steering gear.
1972 Chevy c10 Cheyenne Super
