1 members (Bill Hanlon),
156
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | i have a 52 chevy 1ton. finally got it running. question is when i let the pedal out for clutch no matter how easy i do it, the truck jumps. any suggestions on how to fix it. truck runs and shifts good just when i start out. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Bad spot on pressure plate or flywheel. No easy fix that I know of. Resurface the flywheel and replace the pressure plate and disk.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Not a clutch expert I only had one where the clutch would slip and chatter.
Though I will ask did you check clutch adjustment? Then after that check all of the clutch linkage for excessive binding, play, or parts hanging up.
Most likely new clutch kit - clutch pressure plate, clutch plate, throw out bearing, pilot bearing are needed. But you still have to check everything out. For those new parts are not going to make a bad clutch fork or pivot good. Jeffrey
| | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | Oil soaked linings with make a clutch grabby. The only real good solution to that is to replace the assembly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | ok thanks guys going to inspect better clutch adj etc. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Sounds like oil impregnated on the disc to me as well. I would try to make adjustments first. Did you have the assembly apart? Did you inspect? | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | no paul i haven't taken anything apart yet | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | no paul i haven't taken anything apart yet Well, I would certainly exhaust all efforts to make adjustments before tearing everything apart. Keep us posted on your progress. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Clutch discs, throw out bearings, and anything else lurking in there, that is supposed to be(not mice, yellowjackets, etc., are relatively inexpensive compared to the amount of labor involved, so, while you are there, replace everything, including leaking seals.
Ed
