6 members (texas46, Bill Hanlon, 1955 1 Series, Peggy M, KingG, Brian Moore), 114 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#1187009 10/16/2016 7:49 PM
i have a 52 chevy 1ton. finally got it running. question is when i let the pedal out for clutch no matter how easy i do it, the truck jumps. any suggestions on how to fix it. truck runs and shifts good just when i start out.
jimbo 24 #1187016 10/16/2016 8:16 PM
Bad spot on pressure plate or flywheel. No easy fix that I know of. Resurface the flywheel and replace the pressure plate and disk.
jimbo 24 #1187018 10/16/2016 8:25 PM
Not a clutch expert I only had one where the clutch would slip and chatter.
Though I will ask did you check clutch adjustment?
Then after that check all of the clutch linkage for excessive binding, play, or parts hanging up.
Most likely new clutch kit - clutch pressure plate, clutch plate, throw out bearing, pilot bearing are needed. But you still have to check everything out. For those new parts are not going to make a bad clutch fork or pivot good. Jeffrey
32vld #1187022 10/16/2016 8:33 PM
Oil soaked linings with make a clutch grabby. The only real good solution to that is to replace the assembly.
jimbo 24 #1187024 10/16/2016 9:01 PM
ok thanks guys going to inspect better clutch adj etc.
jimbo 24 #1187101 10/17/2016 10:42 AM
Sounds like oil impregnated on the disc to me as well. I would try to make adjustments first. Did you have the assembly apart? Did you inspect?
Lots more pictures
jimbo 24 #1187240 10/18/2016 3:52 AM
no paul i haven't taken anything apart yet
jimbo 24 #1187258 10/18/2016 10:19 AM
Well, I would certainly exhaust all efforts to make adjustments before tearing everything apart. Keep us posted on your progress.
Lots more pictures
jimbo 24 #1187328 10/18/2016 6:47 PM
Crusing in the Passing Lane
Clutch discs, throw out bearings, and anything else lurking in there, that is supposed to be(not mice, yellowjackets, etc., are relatively inexpensive compared to the amount of labor involved, so, while you are there, replace everything, including leaking seals.
Ed
