4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#1186819 10/15/2016 3:11 AM
1 Offline
hello everyone , been trying to find answers on cam replacement
and adjusting hydraulic lifters . should i pre soak the lifters,
use a break in oil or break in oil additive , run the engine at 1800 rpm or 2500 rpm and for how long ? this is for a chevy 350 engine with 3000 miles on it , need to replace the cam due to a push rod broke and the engine
problem was discovered and another lifter was failing . thank you 1pete1
1pete1 #1186867 10/15/2016 5:04 PM
I just have to know, how do you drive anything 900 miles with a broken pushrod and not know it?
1pete1 #1186934 10/16/2016 3:50 AM
Crusing in the Passing Lane
Now, now.
Ed
