8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series), 120 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
I'm gathering parts to put a 70ish 292 and MY6 transmission into a '68 gmc. I have the aluminum bell housing that was original for the transmission. I thought I had everything I need until I realized that there are no holes in the bell housing to mount the starter. [IMG]http://i305.photobucket.com/albums/nn214/jfnar/68%20GMC/IMG_01301_zps2qev0837.jpg[/IMG]
In all the posts I've read about using the MY6 transmission I don't remember this issue being mentioned. Can someone tell me where I'm going wrong please? This is the last obstacle I have to clear before I install the engine. Thanks.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Your 292 block should be drilled and tapped for a block mount starter.
Evan
I would suspect that the starter would mount to the block the same as a small block V-8. The 292 should have been available with an automatic trans which would also mount the starter to the block.
Fred
Thanks for the info. Fortunately I have a '77 parts truck that has the right starter.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
