1 members (baldeagle),
28
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Anyone with ever install a Bear Trap door latch? Is so, what do you think? Thanks, Scott | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I like the sound of bear trap better! That baby ain't flying open going around a corner. The bear claw latches require some sheet metal hacking to fit them in. I know a local hotrod shop that uses them on all of their modified ADs. They work. BTW, do you know what hurts worse than dropping your drawers in the woods to do your business and sit on a bear trap?
Running the chain taught...
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Carl, hope that is not from experience! | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I used the Trique bear claw latches on my sub and they work good but are a little hard to install.They want to interfere with the window track.
Weeds | | |
