4 members (tclederman, Gray_Ghost, Otto Skorzeny, Shaffer's1950), 111 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
#1184073 09/24/2016 10:13 PM
Hello,
Does anyone know where I could find some tops for a set of parking light bases? I have a good set of bases minus the metal tops.
Russ
Russ,
Is THIS what you are looking for?
Harold
Harold
1- To me the base is the top of the headlamp housing.
2- The glass is the lens, which that link is selling.
3- The long metal piece that holds the lens in place is the parking light bezel.
So to me the "tops" piece he is seeking is No 3.
Russ has to come back and clarify.
Jeffrey
Is this what you are looking for ?
I know it's an ebay ad, so delete after he sees it,if possible.
parking light housing
1951 3100 Chevrolet
That is what referred to as No 3. Though the OP has not cleared up what he was referring to.
I don't need one though thanks for pointing out that you can still buy them. Jeffrey
It was directed to RSWEET, i did a little digging and found them for sale.
1951 3100 Chevrolet
Hi Guys,
The metal top that mounts to the bezel. I know these are different then the 46. It would be the tear drop snapped sheet metal top that holds the glass for the turn signal.
Russ
Hi 32vid,
Those are similar to what I'm looking for, but I believe the 41's are a little different.
Russ
Here's a copy of what I found through Jim Carter's site.
http://jimcartertruckparts.com/images/early%20park%20light%20assemblies.GIF
The middle lamp is what I'm referring too. I listed it wrong, it should have said 1941 instead of 1942. I need the piece that holds the len and screws to the base to hold everything together.
Russ
I would ask if J Carter to measure the distance between the screw holes on the 41 and 42 parts.
Looking at photos of 41 and 42 trucks the headlamp buckets look the same. Maybe someone here can confirm they are indeed the same part. So you should be able to use the 42 parking light parts on the 41 headlamp bucket.
At least you would then be able to use the truck until you find the right parts.
Jeffrey
Are the 1940 Pontiac car parking lights the same ?
1951 3100 Chevrolet
Thanks Jeffrey
Russ, you are welcome.
Jeffrey
