7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,379 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hello,
Does anyone know where I could find some tops for a set of parking light bases? I have a good set of bases minus the metal tops.
Russ | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Russ, Is THIS what you are looking for? Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | 1- To me the base is the top of the headlamp housing.
2- The glass is the lens, which that link is selling.
3- The long metal piece that holds the lens in place is the parking light bezel.
So to me the "tops" piece he is seeking is No 3.
Russ has to come back and clarify. Jeffrey | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Is this what you are looking for ? I know it's an ebay ad, so delete after he sees it,if possible. parking light housing 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Is this what you are looking for ? I know it's an ebay ad, so delete after he sees it,if possible. parking light housingThat is what referred to as No 3. Though the OP has not cleared up what he was referring to. I don't need one though thanks for pointing out that you can still buy them. Jeffrey | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | It was directed to RSWEET, i did a little digging and found them for sale. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hi Guys,
The metal top that mounts to the bezel. I know these are different then the 46. It would be the tear drop snapped sheet metal top that holds the glass for the turn signal.
Russ
| | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hi 32vid,
Those are similar to what I'm looking for, but I believe the 41's are a little different.
Russ
| | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Here's a copy of what I found through Jim Carter's site. http://jimcartertruckparts.com/images/early%20park%20light%20assemblies.GIFThe middle lamp is what I'm referring too. I listed it wrong, it should have said 1941 instead of 1942. I need the piece that holds the len and screws to the base to hold everything together. Thanks, Russ
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I would ask if J Carter to measure the distance between the screw holes on the 41 and 42 parts.
Looking at photos of 41 and 42 trucks the headlamp buckets look the same. Maybe someone here can confirm they are indeed the same part. So you should be able to use the 42 parking light parts on the 41 headlamp bucket.
At least you would then be able to use the truck until you find the right parts. Jeffrey | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Are the 1940 Pontiac car parking lights the same ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Russ, you are welcome. Jeffrey | | |
