1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#1186364 10/12/2016 12:39 AM
I bought a brake line kit from a major vendor and not one of the lines even remotely looks like the originals. The truck is a 57 Chevy shortbed manual brakes. Does anybody know of a vendor that has a kit that works. I hate to keep ordering and have to send them back. The same goes for the emergency brake cables another vendor has metal cased reproductions but they are 66 7/8 inches long and mine measure 62 and out of adjustment so they will never work either. Thanks for your help in advance
I would say inline tube unless that who you used. I have used many of there lines and cables and except for one line (bend in opposite direction) they have been good. They replaced the one that was not right.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks Hambone, it wasn't Inline for the lines but it is them with the emergency cable. I think I might just shorten the original cables and use them the repops don't have the grease fitting on them. I have used the vendor for the lines for 25 years and never had a problem but they were car lines not truck. I think I'll try Inline for the lines and see if they have the correct ones.
Thanks again
I used inline when I did my 59. No problems, fit like the originals. Fifteen yrs ago.
Tommy
59 apache 1/2t
261 short stepside
I had issues with the parking brake cables ( after two vendors, I gave up) ........I added a spacer to make them work.
I purchased a coil of brake line for $30 and made mine using the old lines as the pattern.
Just an update got my new kit, well it at least resembled what it should look like. I had to add to 2 of the lines and shorten 1 of the lines, that was 3 of the 6 lines. The fuel lines look like another mess to make work.
