5 members (Donf, Shade Baby, sron48, Jon G, Bill Hanlon), 141 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
In a hurry as usual so forgot to mark vac hoses where they hook up to intake manifold.
There is a small canister looking thingy at the back of the TH 350 with a tube sticking out of it. I assume it is a vac connection. where does the other end of the hose hook to?
Also where does the brake booster get its vac from?
And the distributor?
Thanks for helping out the doofus.
Weeds
Constant vacuum source on the intake. Not carburetor.
Riding in the Passing Lane
There is an outlet on the intake man. in back of the carb. A fitting goes in it to connect the hose to the trans. modulator & the power brake. The mod. uses 1/4 in hose while the pb uses 3/8. The dist connects to an out let on the carb. Some carb outlets are constant manifold vacuum while at least one is ported vacuum. Ported vacuum has vacuum only at part throttle. Use one of these for the dist. vacuum advance. 3/16 hose. It takes some research & experimenting to find which works best for your engine.
1972 Chevy c10 Cheyenne Super
Roy and Wrench, Info on vac connections much appreciated. Running out of warm weather here in WI. Might have to shut down until next spring.
Weeds
