1 members (Shade Baby),
152
8
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The Suburban ran great last night after I got the old fuel out of it. It ran great this morning going to town. Then coming home it took some intermittent sputtering spells Then it started losing power on the same stretch of road where it started when I had the old gas in it.
Now I'm thinking I have a loose terminal somewhere in the ignition system. Or maybe the Pertronix unit is playing tricks on me. Anyone ever had one flutter before dying?
What else should I be looking at? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Vapor lock? Fuel supply problem? got a filter or glass fuel pump you can jump out to check when it happens? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Maybe water in the tank from the corn squeezeins!
| | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | I had the coil wire to my distributor come loose one time and it would randomly bounce around and be an intermittent connection. It was somewhat held in place by the boot and looked ok, but was really not secure in the socket and was probably moving around from the fan wash at speed. Maybe check all the plug wires? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I took the Suburban for a test run today to try to duplicate the problem. It ran great for 40 miles. Have no idea if/when it will screw up again.
Before I left I checked over all ignition and plug wires. No loose connection. I ran some fine sandpaper over the rotor contacts but I don't think it needed it.
My theory now is there was still some moisture in the tank after I pumped out all the pick up would reach. While sloshing around in the tank while on the highway some of it gets sloshed up into the pick up. Sound possible?
Seems like I have read of a product that will absorb moisture in a tank and make it harmless. Anyone know what it would be? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Sta-bil is one such product that has been around for quite a while. Readily available at flaps, Walmart etc.
Ed
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | When I lived in upstate NY the winter of 86 everybody used isoprol alcohol. 1pint/tank Every tank from the really cheap stations.
| | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | SeaFoam has enough alcohol in it to absorb moisture, or you could just go to your friendly local drug store and get a couple of pints of 91% rubbing alcohol for somewhat less money. Either one will de-water the fuel tank. Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | methyl hydrate [methanol] is a gas line antifreeze, neutralizes water - found as thinner for shellac
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Post time 3:21 A tie for the same solution ?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks for the replies. I'm going to take it to town to the car wash later. I'll pick up a couple of bottles of rubbing alcohol while in town and give that a try. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You can get a product called HEET at your local FLAPS. Removes water from the tank. Been around for years.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I poured a quart of 91% rubbing alcohol in it this afternoon. Now it has 'til Sunday to work it's magic before I drive it to Fort Worth for a show. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Gonna have trouble keeping it between the lines?
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Let us know what works. -W | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, made the show in Fort Worth today with no problems. Truck ran like it should. A little over 100 miles round trip. The rubbing alcohol must have done the trick. Thanks for the hot tip, guys. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Interesting to me that the often maligned as evil, alcohol, was the cure for your problem. I have no doubt that it did solve the problem. Alcohol has been sold for decades as a water eliminator in gasoline.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I think it was the fuel, maybe time and your filter will tell. They used to sell a water atomizer to install into carb to give more Ooompf. Go figure. I think it's more the fact you are running it. Also I used to use Isopropyl Alcohol in cars that could not pass emissions and then they did. Either way, glad it runs good, hope it stays that way. Pour some Sta-Bil in if not driving much. Don't tell us what you did with the old fuel.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | "There's no fuel like an old fuel!" Everybody knows that!  Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "A little moonshine for me- a little for the motor...a little for me- a little for the motor, a little for me- a little for me"...
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | The oldtime dirt track racers who came to Nashville from Chattanooga over in the east Tennessee mountains used to have a saying: "A race car needs water and alcohol- - - - -water in the radiator and alcohol in the driver!" Jerry
