2 members (Woodcmiami, Mike Roache), 138 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1184328 09/26/2016 8:43 PM
Help...
It started some time back when we took apart the side hood panel latches to get all (or most) of the rust off.
In doing so, I think we had some help and the small brackets that hold the rotating rod to the hood side panel are now missing. See the red areas of the following Picture http://i1296.photobucket.com/albums/ag13/catfish_fry/HoodLatch_zpsefg3dum4.jpg
We plan on making new brackets and fastening with SST screws but it would most helpful if someone could measure the distance from the inner side hood surface to the center (or side of rod closest to the hood and post that. This will allow us to make the brackets with the proper space in there.
Thank You Very Much
DLBrooks
DLBrooks
I am sure you can make these, Or someone can send you 4 of them. I have 2 hoods I am not restoring. Probably a lot of others out there. I will try to make your measurements. I measured from hood not bracket brace to center of rod and I have 11/16". The firewall brackets have some adjustment on them.
The hole for the rod was punched on originals for added surface for the rod rotation.
1959 GMC 100 Fleet
Follow in the DITY
DLBrooks
DLBrooks
Measured again at 23/32". Rods probably get slightly warped from closing pressure.
Measured next to verticals from side hood surface.
Brackets are 3/4" on base and 1" to pyramid top on vertical.
Do you want pics?
1959 GMC 100 Fleet
Follow in the DITY
DLBrooks
DLBrooks
http://67-72chevytrucks.com/vboard/showthread.php?p=7731561#post7731561
If painting you might not want stainless, if do sandblast then etching primer on whatever you use.
1959 GMC 100 Fleet
Follow in the DITY
Thank you very much for the measurements.
This should be enough information for us to make them.
Have a great day.
