2 members (artinva, Chip O),
112
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | OK All,
I did a search and did not find much info or pictures. I am trying to assemble my doors on my 50 1/2 ton. First question is do I remove the window to install the channel? My old channel had metal strips to hold the channel in place. How is the new one held in place? Do I have to add my own screw holes? The order of installation should be, outer window trim, channel, rubber wiper, felt wiper and then the inner trim? Does anyone have a good website that has a step by step of door assembly? thanks, skipper | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | skipper, Do you have a Shop Manual? If not, original ones can be purchased on eBay and maybe from manual venders; and, reproduction manuals can be purchased from many of the b=vendors listed in the Tech Tips; and, a 1948-1951 Chevrolet Truck Shop Manual is on-line. If that does not help, keep asking questions. Good luck, | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | OK All,
I did a search and did not find much info or pictures. I am trying to assemble my doors on my 50 1/2 ton. First question is do I remove the window to install the channel? Answer: Yes. My old channel had metal strips to hold the channel in place. How is the new one held in place? Do I have to add my own screw holes? Answer: I use small, short self-tapping Phillips head screws, after I finish shaping the channel by rolling the window up. The order of installation should be, outer window trim, channel, rubber wiper, felt wiper and then the inner trim? Answer: Your order of assembly is correct. The felt wiper is to be attached to the inner trim prior to installing the inner trim to the door. Does anyone have a good website that has a step by step of door assembly? thanks, skipper
