1 members (J Lucas), 94 guests, and 0 robots.
Topics128,049
Posts1,055,635
#1184869 09/30/2016 6:43 AM
OK All,
I did a search and did not find much info or pictures. I am trying to assemble my doors on my 50 1/2 ton.
First question is do I remove the window to install the channel?
My old channel had metal strips to hold the channel in place. How is the new one held in place? Do I have to add my own screw holes?
The order of installation should be, outer window trim, channel, rubber wiper, felt wiper and then the inner trim?
Does anyone have a good website that has a step by step of door assembly?
thanks,
skipper
skipper,
Do you have a Shop Manual?
If not, original ones can be purchased on eBay and maybe from manual venders; and, reproduction manuals can be purchased from many of the b=vendors listed in the Tech Tips; and, a 1948-1951 Chevrolet Truck Shop Manual is on-line.
If that does not help, keep asking questions.
Good luck,
Originally Posted by rc356s
OK All,
Answer: Yes.
Answer: I use small, short self-tapping Phillips head screws, after I finish shaping the channel by rolling the window up.
Answer: Your order of assembly is correct. The felt wiper is to be attached to the inner trim prior to installing the inner trim to the door.
thanks,
skipper
