| | | Forums66 Topics128,189 Posts1,057,222 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 24 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 24 | The 1948 GMC door window glass surround (door glass frame) is secured to the lower piece (channel) by 2 very small screws on each window. Are replacements available? I can't find them at the usual parts vendors. Mine are rusty, I'd like to drill them but only if something can easily replace them. Thx.
1948 GMC 1.5 ton Dump Truck
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Try your local hardware store. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you have a local Ace they will have them, you may have to shorten a longer screw but they will have something. | | | | | Joined: Mar 2012 Posts: 24 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 24 | Ok, thanks for the suggestions. From the parts book, and from drilling the head off one, it looks like a 6-32 flat head screw from one end and a 6-32 flat head sleeve from the other side. I'll check locally.
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Classicparts.com sells the screws and, the brass sleeve nuts which they screw into for $4.95 for both doors. Carl
| | | | | Joined: Mar 2012 Posts: 24 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 24 | That's them. Thanks! Seems like not all the parts supplies carry them.
| | | | | Joined: Apr 2011 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 22 | You can buy the tree nuts and brass screws at the hardware store. You just need to grind the nuts a little bit.
When setting goals in life. Always aim low to avoid disappointment
