6 members (Hotrod Lincoln, Otto Skorzeny, Peggy M, 1955 1 Series, GRNHydra, 1 invisible), 84 guests, and 3 robots.
Topics128,095
Posts1,056,494
Members48,444
Wanted to remove the pilot bushing from my 235 I am cleaning up for my '58 Apache, but could not get the bearing removal tool, I rented from a local auto parts store, to fit inside the bearing. Scratching my head, I resorted to the Internet and of course, YouTube.
Found 2 or 3 videos where guys used wet paper and a bolt to drive the wet paper into the space behind the bushing and the back of the crankshaft. Didn't put much credence in this working, but what the heck.
It worked! The pressure created by continuing to pack this space with wet paper forces the bushing out of the camshaft. You can actually see the bushing slowly coming out. Of course my engine is out of the truck, with the clutch, flywheel, bell housing, etc. not yet installed, and the engine is supported on a wooden frame/stand that sits low to the floor.
I was amazed and have shared this with my 'go-to-guy' at the local auto store where I rented the tool that would not work.
Any other bolters ever removed a pilot bushing this way?
I've used heavy grease and the alignment tool in the same manner. Worked great.
Dennis
40 Chevy 1/2 ton
Dennis,
I'm curious. Was your engine also out of your vehicle when you did this?
H Online: Content
The simple way is to screw a big threading tap into the bushing. When it bottoms out against the crankshaft, keep turning and the tap jackscrews the bushing out. I think a 5/8" tap works, either coarse or fine thread.
Good morning Jerry. Hope you are doing well.
Using the tap was certainly a possibility and would have definitely worked. I was trying to salvage the bushing in this case.
Yes, the engine was in.
Dennis
40 Chevy 1/2 ton
All good methods and they'll all work in or out of the truck just the same.
Here's another, a tapered screw deal with a grease fitting. A grease gun provides the hydraulic pressure to jack it out.
Made by Lisle, part number 55600
https://images-na.ssl-images-amazon.com/images/I/41nIMXvRKdL.jpg
•1952 Chevrolet 3800 pickup
---All pictures---
I did the same thing DennisM did. Heavy grease and a wooden dowel sanded down to fit in the bushing I ended up wrapping masking tape on the end of the dowel to get the fit just right. Add a bunch of grease to the ID of the bearing. Insert dowel and tap end with a hammer, keep adding grease as needed.
Worked great !
Clem
59 Chevy 3600
New Hampshire
