1 members (porsche), 111 guests, and 1 robot.
Topics128,051
Posts1,055,767
#1183900 09/23/2016 8:08 PM
Fox
Offline
How exactly is the outer trim of these trucks attached? I have a 70 1/2 ton that is a lower model truck without the trim. Eventually I would prefer a two tone with white and the trim, but if it means punching holes in the sides I might change my mind.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1184185 09/25/2016 7:10 PM
2 Offline
The trim is held on by multiple holes with metal clips.
Richard
42 Chevy pickup
65 Chevy C10 Panel
Fox #1185544 10/05/2016 2:17 AM
They were originally held with metal clips along a series of holes in the body. The shorter strips around the cab corners and such had studs that you bolted from the inside of the cab. But if you order new ones from say LMC they now come with adhesive backed clips. Or you can order the adhesive clips alone and use with the original moldings if you have them.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
