| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | How exactly is the outer trim of these trucks attached? I have a 70 1/2 ton that is a lower model truck without the trim. Eventually I would prefer a two tone with white and the trim, but if it means punching holes in the sides I might change my mind.
| | | | | Joined: Jun 2005 Posts: 45 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 45 | The trim is held on by multiple holes with metal clips.
Richard 42 Chevy pickup 65 Chevy C10 Panel | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | They were originally held with metal clips along a series of holes in the body. The shorter strips around the cab corners and such had studs that you bolted from the inside of the cab. But if you order new ones from say LMC they now come with adhesive backed clips. Or you can order the adhesive clips alone and use with the original moldings if you have them.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
