BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2008 Posts: 888 'Bolter | 'Bolter Joined: Apr 2008 Posts: 888 | Received brand new vanity plates today and wonder if anyone has experience with a clear spray that will protect it from fade in the sun. Lots of products out there but don't know how effective they are.
Ed
| | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 | A lot of the "clears" will yellow over time. Maybe just a good paste wax every few months.
| | | | Joined: Oct 2002 Posts: 4,066 Bolter | Bolter Joined: Oct 2002 Posts: 4,066 | I have never seen a license plate fade from the sun..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | Joined: Apr 2008 Posts: 888 'Bolter | 'Bolter Joined: Apr 2008 Posts: 888 | NV just started a mandatory (money grab) program that requires plates be replaced every 8 years because they become "illegible" to law enforcement. So instead of making them better the taxpayer just gets to pay an extra "fee" annually. Good stuff!!
Ed
| | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 | Oklahoma just started the same program.
| | | | Joined: May 2005 Posts: 8,988 Sir Searchalot | Sir Searchalot Joined: May 2005 Posts: 8,988 | Why protect it if you have to replace? Nothing known to mankind, that would be legal to do, will keep the sun from degrading the paint/ink. It's about $1.25 per year for a new plate. $10/8 yrs. Something with UV protection may help a little. But may react to the paint or cause more fade or as said, yellow. I would just not worry about it and drive on. Respectfully, Sir. | | | | Joined: May 2012 Posts: 574 'Bolter | 'Bolter Joined: May 2012 Posts: 574 | Oklahoma just started the same program. Does it apply to our new plates somehow? I hadn't heard yet, glad to know an Oklahoma lawman that knows what's going on!
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 | Next time you go to renew your tag sticker you will be charged for a new plate. Only way around it is "Vanity Plates" and even then you will receive new regular plates every so often. In Oklahoma you must keep the regular plates in the vehicle even if you have "Vanity Plates". The justification as stated by Fourty9 is to make it easier for Law Enforcement to read your plate. Bunch of carp, just another way to raise taxes.
| | | | Joined: Jul 2010 Posts: 592 Shop Shark | Shop Shark Joined: Jul 2010 Posts: 592 | This stuff works great on old license plates that I have restored. It is expensive, but it works great. I try to have a few things to clearcoat when I use it so that I can get my money's worth. http://www.spraymax.com/index.php?id=361&L=1It is a two part automotive clearcoat. Results on small projects can be as good as with a gun. Once you pop the seal and mix in the catalyst, it has a 48 hour shelf life. This can be extended another day or so by keeping it in your refrigerator. I would not recommend the 2K Rapid Coat. It is VERY fussy about flash time. The regular 2K is more forgiving. I allow about 20 minutes flash time between coats. Matt | | |
