6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
Kind of a long post... I'm having trouble identifying a 4L80e core I just recently purchased for my 1953 2-Ton GMC project. A little background in case it helps:
I originally wanted to use the NV4500 5-speed manual for this project. But for reasons I haven't figured out yet, rebuildable cores in this area seem to be insanely priced. I estimated after a good quality rebuild kit and the special synthetic fluid the NV4500 needs, I would be out close to $1,500 before I had a usable transmission. That doesn't even include the costs for the bell housing, flywheel, clutch, hydraulic throw-out bearing, and all the mechanism to make it work. So I decided to try using an automatic in the project instead.
My heart doesn't completely approve, but my head has convinced me that it will be a much easier swap with the 496 big-block bolted in front of it. The overdrive will also allow me to preserve the original Eaton 1350 two-speed. I also managed to find a used but good stand alone electronic controller for the transmission as well.
So my problem is this... I don't seem to be able to date this transmission. I know that GM is typically good about marking their components so the repair industry knows what the're working with. The 4L80e has gone through several phases of improvement through the years as they flushed out reliability issues. I've been told it's important to know as much as possible before ordering a good overhaul kit. This is what I do know:
I have the later version of this transmission due to the cooler line spacing. I know it came out of some medium-duty truck due to the emergency brake drum at the tail (very helpful for my project because the Eaton 1350 two-speed has no provisions for an emergency brake). The transmission was rebuilt at some point by the Goodwrench franchise. Is it possible they changed the ID tag at rebuild?
The transmission ID tag below in the pictures kind of feels like it's the original. The tag shows a code number of: 04WB P7, and the Serial number is: 07318 089
After an exhaustive Internet search through GM transmission codes, my numbers don't seem to come up. Any one here have access to better data?
Images below. Thanks in advance for your help.
Drivers Side of Transmission
Passenger Side of Transmission
Evidence of Previous Rebuild
Missing Bar Code Sticker from Normal Location
Transmission ID Tag
-David
1953 2-Ton GMC
OK, after some more searching, I think this thing was built in 2007. The day is possibly the 29th of June. I've ordered a service manual for this thing in the hopes it tells me more. I think having the year is enough for me to get a master kit... I will share how I found this information in the hopes it helps someone else when I am sure I'm correct...
-David
1953 2-Ton GMC
David, I'm helpless in helping you with your dilemma and curious as to the info you found.
I have a 700R4 that did not have the number where its suppose to be and, if the tranny guy is correct, he told me the number was filed off because it was a remanf. tranny. Since yours was "rebuilt" maybe some numbers were taken off????
No help to you but just my thoughts. Keep on trucking brother.
OK, After too much research, and reading hundreds of pages of online chatter, I think I have some useful information to share...
The GM 4l80e overdrive automatic transmission turns out to be a super piece of engineering. It's gone through a bunch of updates over the years, and is identified (in a sort of sloppy way in my opinion) between what most call the "Early" and "Late" models. The early model is defined as between the years 1991 and 1993. 1994 to 1996 models are considered a group on their own, and anything 1997 on is considered the later model (some even say the 1995 on is the later model).
The biggest changes in my opinion that you need to concern yourself with are things like electrical changes, cooler line placement and ECM compatibility:
In 1993 the outside connector and internal wiring harness was changed. This would require modifications to your harness.
In 1994 the electronics where updated, specifically the PWM force motor carrier frequency was changed from 292.5 HZ (earlier model) to 614 HZ. This would require a ECM change.
In 1997 the cooling line hook-up was changed moving the return line more toward the center of the transmission for improved lubrication. This would require some reworking of your cooler lines.
There are a bunch of other updates, but the ones I mention above are in my opinion the most important when considering using this transmission. So...
I found some not so reliable chatter about using the serial number on the metal ID tag to date this transmission. Not reliable because there seems to be several opinions on what these magical numbers mean. Plus I found talk about how some rebuilders would change the serial number to reflect the date the transmission was rebuilt.
I also stumbled across a huge list of code numbers and their corresponding models and years for both the 4l60e and 4l80e. I consider this list way more useful. This second list is copied from a forum page found here (scroll down on the page to see everything): 4l80e and 4l60e Code Numbers
The list comes from some kind of subscription only service. I was unable to enter the site simply because I haven't paid the entrance fee. The site is found here: Subscription only site...
I copied and pasted the list from the forum and created a .pdf file (for my own convenience) and I'm happy to share it with anyone who wants it. All the information in the list I made is from the forum link above. I'm not sure if the StoveBolt forum will allow uploading a file, so if you want the information, just send me a pm with your email address and I can email it to you.
So what did I learn about the metal ID tag? They come in yellow, blue, and green. There is a bunch of chatter online about the green tags being put on the transmission at the time of rebuild (Goodwrench franchise does this maybe?).
I have learned that if you take the code number from the metal ID tag, drop the first and last characters, the remaining code can be used in the list to hopefully find what year and application the transmission was originally from. In my case, the code says: 04WBP7. Drop the first and last leaves 4WBP. In the list, it says this transmission came out of a 2004 Izusu Workhorse, NPR, Tilt Cab box truck. This makes sense because the guy I bought the transmission from says he was told it came from some kind of box truck.
I hope this proves to be useful to others.
Thanks and take care.
-David
1953 2-Ton GMC
