Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (Jon G, JW51, kades51, baldeagle, 68ironhead, Stovebolt48, GMCJammer51, dt235sd, 1 invisible), 55 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#1184012 09/24/2016 4:25 AM
Z
Z Offline
Today all was well on a drive in my 1/2 ton with 3 speed shifter on the floor. Stopped at a stop sign after about a 1/2 hour driving and proceeded to go forward from first to 2nd with no problems but then it would violently pop out of 3rd.
Before I pull the tranny out and open it up i want to see if there is any other reason it would it would start giving a problem of this description.
I have checked the shifting rods and everything is good and tight and nothing has moved. With the engine off it will shift into all gears smoothly but with the engine running it will pop out of 3rd.....the clutch acts the same as it always has.
Anyone have any suggestions before I pull the tranny out ????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
zoegrant #1184044 09/24/2016 5:08 PM
You could jack it up with the wheels off the ground and disconnect the 2-3 shift rod. Put the lever in 3rd gear, start it up and see if it will stay in gear.
If it still pops out, you could have a worn syncro assy, shift fork, or both.
Fred
zoegrant #1184057 09/24/2016 9:03 PM
Z
Z Offline
Thanks for the info Fred....I just tried it and it still wants to keep popping out....my niece wanted to use the truck for her wedding pictures but she will have to make other plans....
