9 members (dt235sd, Gdads51, Gib70, 3B, Phak1, 32Fordpuchoptop, 68ironhead, Jon G, 2-Ton), 79 guests, and 0 robots.
Topics128,049
Posts1,055,693
#1183059 09/18/2016 3:30 AM
I'm still confused about 292 swap in my 53 3100. I plan an aluminum radiater with electric fan and muncie M22 trans. I have heard move the radiater foward. How much room do I need. This may be a dumb question but that has never stopped me before. Why can't I move the engine back and alter the firewall a little bit. That way the radiater looks right. I have not installed moter mounts or cross member yet.
mick53 #1183061 09/18/2016 3:41 AM
If you have the leg room, no problem with moving firewall. I would set in the truck for a while and see how the pedals would feel moved around a bit. I moved the engine back in my '37 never thinking about how it would effect the throttle pedal location. I wish now I would have something different.
Joe
mick53 #1183081 09/18/2016 4:27 PM
Crusing in the Passing Lane
It appears that several have moved the radiator fwd a slight amount with no noticeable outside appearance change. Get your tape out and measure. Moving the firewall aft is a lot of work as well as a loss of legroom.
Ed
mick53 #1183087 09/18/2016 5:07 PM
I put a 292 in a 1950 truck and a 1940 car without moving the radiator. By using the 230/250 style pump which comes in a very short option and a flat face fan I had no problem.
My Blog
mick53 #1183141 09/18/2016 11:15 PM
Thanks guys when I do my mock up now I have some options.
mick53 #1183156 09/19/2016 12:46 AM
Many just mount the radiator to the front side of the radiator mount. These cabs are not that large to start with.
mick53 #1183204 09/19/2016 4:30 AM
Can't I just make the dent in the firewall deeper?
mick53 #1183207 09/19/2016 5:03 AM
When the engine position is a problem, some hotrodders use the tub section of a wheelbarrow to move the middle of the firewall back. It's stamped out of good-quality steel, and all the compound curves are already there. Just trim it to fit and MIG weld it into position.
mick53 #1183211 09/19/2016 5:31 AM
When we setup 292's in these the bell mounts are located correctly and denting the firewall doesn't help with fitment. Moving the radiator to the front of the support and modifying the upper and loser valances to fit makes it look original. it changes nothing to the outside appearance.
http://www.thehollisterroadcompany.com/media/1947_3800/Fenderon/47truck%20004.JPG this is a 292 with the radiator moved forward. We used a Taurus fan but a steel fan will fit with no issuses
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
mick53 #1183293 09/19/2016 9:50 PM
Nice looking truck. Thanks for the info. I'm learning.
mick53 #1183776 09/23/2016 12:00 AM
My 52 truck had a 292 when I got it. It is a Canadian big bolt, but length shouldn't be any different. Rad was flush with the frame on the engine side, and custom mounts welded to frame for engine, otherwise no chassis changes seem to have been done. Not sure if rad mounting was even modified. I can get you some pictures if you like.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
