0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 1,060 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,060 | I'm still confused about 292 swap in my 53 3100. I plan an aluminum radiater with electric fan and muncie M22 trans. I have heard move the radiater foward. How much room do I need. This may be a dumb question but that has never stopped me before. Why can't I move the engine back and alter the firewall a little bit. That way the radiater looks right. I have not installed moter mounts or cross member yet.
| | | | | Joined: Feb 2000 Posts: 5,266 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,266 | If you have the leg room, no problem with moving firewall. I would set in the truck for a while and see how the pedals would feel moved around a bit. I moved the engine back in my '37 never thinking about how it would effect the throttle pedal location. I wish now I would have something different.
Joe | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It appears that several have moved the radiator fwd a slight amount with no noticeable outside appearance change. Get your tape out and measure. Moving the firewall aft is a lot of work as well as a loss of legroom.
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I put a 292 in a 1950 truck and a 1940 car without moving the radiator. By using the 230/250 style pump which comes in a very short option and a flat face fan I had no problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2016 Posts: 1,060 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,060 | Thanks guys when I do my mock up now I have some options.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Many just mount the radiator to the front side of the radiator mount. These cabs are not that large to start with. | | | | | Joined: Apr 2016 Posts: 1,060 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,060 | Can't I just make the dent in the firewall deeper?
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | When the engine position is a problem, some hotrodders use the tub section of a wheelbarrow to move the middle of the firewall back. It's stamped out of good-quality steel, and all the compound curves are already there. Just trim it to fit and MIG weld it into position. Jerry
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | When we setup 292's in these the bell mounts are located correctly and denting the firewall doesn't help with fitment. Moving the radiator to the front of the support and modifying the upper and loser valances to fit makes it look original. it changes nothing to the outside appearance. http://www.thehollisterroadcompany.com/media/1947_3800/Fenderon/47truck%20004.JPG this is a 292 with the radiator moved forward. We used a Taurus fan but a steel fan will fit with no issuses | | | | | Joined: Apr 2016 Posts: 1,060 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,060 | Nice looking truck. Thanks for the info. I'm learning.
| | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | My 52 truck had a 292 when I got it. It is a Canadian big bolt, but length shouldn't be any different. Rad was flush with the frame on the engine side, and custom mounts welded to frame for engine, otherwise no chassis changes seem to have been done. Not sure if rad mounting was even modified. I can get you some pictures if you like. | | |
