| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | On a 62-66 C10, is there a difference in the passenger side and driver side headlight mount? I was having a hard time adjusting my driver side headlight because the left/right adjustment screw was on the right hand side (when facing the front of the truck), as well as the spring. Since there is a square hole on the left hand side of the headlight backing plate for an adjustment screw, I moved it over there. This is the way the picture in the assembly manual shows. But in order to use the adjustment screw in the slot in the mount on the left, I had to rotate the mount counter-clockwise, which in turn made the bulb tabs not fit into the mount so that the bulb can sit upright and the bulb now sticks out further than the passenger side by about 1/4 in. Is there something else I need to do, or do I need to put the adjustment screw back into the right hand hole? Seems that the screw stays loose no matter how far I back it out to adjust the light to towards the passenger side. Thanks all!
'If you want to test out a truck, buy your own dang truck!' -CSM Fulk, Iraq
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I'm going to a junk yard tomorrow, I'll look at a truck and let you know what I learn.
Best I recall, the adjusters are on the outside edge of the bucket tho..
1959 3100 Apache Fleetside
