11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Hi I joined stovebolt 15 years ago or so. haven't used it much I have 51 3100 pickup. I started a on cab restore several years ago but stop, moved bought new hous or two and worked on them. But now I want to start working on the Old truck. Need info on what rear end, trans, etc and what years fit Dave J. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have a '50 3100 with a '53 235, a 1985 T5 transmission, and a 2001 Nissan Xterra rear end. These mods were surprisingly easy to make. The Nissan rear end comes with the 6 lug Chevy bolt pattern, the correct width, and limited slip rear axle. The parking brake arrangement makes for a very simple hook up with the stock assembly. One issue with it however, is that it has a 4.64 to 1 gear ratio. Just make sure that the transmission that you choose has a .72 to 1 fifth gear ratio (overdrive).
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are asking what years would be stock/period correct, you've asked in the right place. If you want to modernize it, you should ask in the HiPo forum.
To keep it stock a '49-'53 engine, transmission and rear end would be needed. A '54 235 or 261 would be a period correct upgrade. A '55.2-'62 235 or 261 can be used with slight modification to the water pump. | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Thanks 52Carl for getting back to me. Now I need to find out if the tranny I have is .72 to 1 gear rato. it came form a 72 Camaro. Do you happen to know what numbers I need to look for, and where | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | thanks Cleis for the help
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Need to know what transmission you have.
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you have a 5 speed from a Camaro, look where the case splits into the tail shaft. There should be a tag that has a number that begins with 1352---. that's the number you need. If it is an original trans from a 72 Camaro it's probably a Saginaw or a Muncie 4 speed. The ratio would be 1 to 1.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Thanks Tommy I'm out of town until first of the week, I'll the numbers and get back to you when I get Home Thank again Dave J.. | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Tommy I back home and I try to find a name plate or something on the Tranny. I can't find anything.But I don't think I mentioned that is a Automatic. So if that helps, can you give me any info? Thanks
dave J.... | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Automatic in a 72 Camaro would be either a Powerglide (2sp) would have drive, low,or a 350 turbohydramatic which would be a (3sp)would have drive, L1, L2. What engine was originally in the Camaro? 6Cyl or V-8.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
