3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I currently have the grill out of the truck for repair and new paint. The three vertical supports are factory black, but need to know the inside color of the two vetical end pieces. Is it the same as the horizontal light gray back bars? Thanks, Steve | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Steve,
I have a 53 3100. If I am understanding correctly, they are the two vertical end pieces of the outside ends of your grill. They are riveted onto the ends of the grill bars. They have a couple of square nuts welded into them, to bolt the body. When I took my grill out, those two pieces were painted the same color as the factory body color. Hopefully this helps you out.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From Jim Carter: The 1953 “back splash” on painted grills was light gray (Thistle Gray) to match hub caps and bumper. (as posted above by Rugo) | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Rugo, thanks for that info. I know the outside edge of those end pieces are the body color but was not sure about their inside color. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, I know the back splash horizontal bars are thistle gray, but I was unsure about the two ends that Rugo mentioned. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Well, I just made an interesting discovery. After removing the two ends I found the original dark green body color on the inside after sanding off some P.O.'s white paint. I guess that answers the original question. Thanks guys, Steve | | |
