3 members (Ponchogl, DadsFirstPickup, Otto Skorzeny), 204 guests, and 5 robots.
Topics128,107
Posts1,056,225
Members48,436
I read an article in Vintage Truck magazine where the owner used a roller to apply clear coat to the old paint on his old truck. I'd like to try this on my 52 Chevy truck. Its paint job is about 25 years old and looks pretty good from 20 feet away. My problem is that the truck sits outside in warm weather and the paint chalks a lot. I'm getting tired of spending hours using a cleaner/ wax to get the shine back. I am hoping some clear coat would stop the chalking and protect the paint. Can anyone recommend a clear coat I could apply with a roller or brush that wouldn't look like it was applied with a roller or brush?
My dad always told me, "Don't force it, get a bigger hammer".
Doesn't rustoleum make a roll on clear?
Give me ambiguity
or give me something else
You will have to ask at your local paint supplier .
I used a brushing grade paint (on my bus) from our local Resene Paints, called Uracryl 400 series, it is 2 pac, very durable.
http://www.resene.co.nz/archspec/datasheets/ra55-Uracryl-402-Semi-Gloss.pdf
There must be something you can get locally that will perform the same.
I would NOT apply clear with a roller or a brush!!! The chances it will look worse than the current finish is very high.
The prep prior to clear coating would be acactly the same ( spray vs roller/brush) and accounts for 70-80 % of the cost and work. If cost and equipment is the issue ......do all the prep and have someone spray the clear.
We used to take our own paint to Macco and have them spray it for us in there booth. Seems like we got a discount for suppling out own paint. We did the prep work.
Words to live by!
Take it to a local detailer and have them take a look at it. They nay not be as expensive as the ckear coat and will do a better job!
The paints used back in the day didn't have clear so they needed buffing to keep the shine. It's part of owning a truck that doesn't need paint today because it's still really a nice truck.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
