1 members (Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,080
Posts1,055,951
Members48,430
#1181305 09/05/2016 10:05 PM
Does anyone have a good photo of the brake pedal return spring set up? I have a 52 3100. Just finished routing new front brake lines, it's been apart so long i don't recall how and where the spring connects and is there a rod that goes with it? Cant get a clear enough idea from the shop manual.
Joe
Fox Offline
Joe,
I have that picture, I would just need to dig it up for you. Maybe his weekend. I think you're right. The brake spring connects to the brake pedal, then to an "extension rod" that connects to the little tabs that come inward from the frame under the exhaust.
I'll do some digging because a picture says a thousand words.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Thank you fox
Fox Offline
Joe,
I'm still looking for my camera cable to upload a good picture from my "old shop camera" to the computer. I have a really good one of everything all cleaned up. The fuzzy one is when I tried to take a picture of the camera screen. In the meantime, I ran out to the farm and took a couple pics of a parts truck. This is on a 51 Chev 1/2 with a 3spd.
http://s1372.photobucket.com/user/foxj12/library/?view=recent&page=1
The clutch spring connects to the clutch fork and then that has a 1/4" (?) diameter rod that goes to the pedal. The brake has the spring and then the little spring rod extension.
The springs attach to the frame on the little tabs that stick out under the exhaust. The brake goes to the top and the clutch to the bottom.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
jremig....
Check your PM.
Mike
Mike
1951 3100 5 window
I am also looking for a good picture of the return springs, along with shifting linkage for 3 on the tree and clutch linkage.
