Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#118209 10/27/2005 8:05 PM
I am doing the metal work on my '52 3100 and I have been reading about the metal shrinking disk.
I think this would be very helpful has anyone used this?
Would you recommend it?
Where can I get one?
#118210 10/27/2005 9:07 PM
I have many hours invested in using a shrinking disc. It does work to shrink the high spots but I have found it to be very slow going. You would use the disc if you did not want to use any body filler. I bought mine from one of the members on the site listed below. I don't remember his name for sure (John Kelly ?) but questions on this site will bring a response from him. He has a web site with some good pictures of his excellent metal work.
http://www.allshops.org/
Here he is www.ghiaspecialties.com
#118211 10/27/2005 9:10 PM
Thanks ... I reached John via e-mail and he is still selling them.
From your experience would you just use body filler then waste the time trying to get it perfect?
#118212 10/27/2005 9:12 PM
#118213 10/27/2005 9:14 PM
Sunchaser Tools
I have never used one but I have seen one used by an expert panel-beater. He was able to do magical things with metal with this tool (and he could also pick, hammer, and shrink - without the tool). He preferred the Sunchaser Shrinking Disk to more traditional techniques.
#118214 10/27/2005 9:25 PM
I get the metal as perfect as I can without using the disc. I'm using body filler (All Metal). When I started I tried to get the metal perfect without using any filler. I'm glad I did that but it's just too time consuming.
#118215 10/27/2005 10:08 PM
I was looking at the Sunchaser disk but you have to purchase the whole kit which isn't cheap.
Rusty46 ... can you explain "I'm using body filler (All Metal)"?
Does this literally mean that you are using All Metal(lead or something)?
#118216 10/27/2005 10:44 PM
All Metal is a brand of body filler that uses aluminum powder instead of talc. It dries harder and does not absorb moisture. It's also harder to work with and more expensive. Usually used in an area that may encounter moisture, possibly from the back side. Unnecessary in normal body work.
You can make a shrinking disc from a stainless lid for a cooking pan. I think John Kelly has some information on his site.
